Введение
This guide will walk you through how to remove and replace the circuit board should your device be broken or malfunctioning. You will need a # 1 Phillips Head screwdriver, a plastic opening tool and tweezers. This easy process should take no more than 15 minutes.
Выберете то, что вам нужно
Unlock the battery cover by sliding the switch to the unlock position.
Remove the six 1mm screws from the back and upper casing with the Phillips Head screwdriver.
Remove the two 1mm screws and separate the circuit board and camera from the plastic casing.
Unscrew the two 1mm screws from the board shown. Remove screen from circuit board.
Еще один человек закончил это руководство.
