Введение
This guide provides simple, step-by-step instructions for safely replacing the fuses in your Fluke 175 Multimeter. Keep your multimeter functioning accurately with this easy maintenance tip.
Выберете то, что вам нужно
Turn off meter and disconnect test leads.
Remove the test leads and any input signals before replacing the fuse.
Use ONLY fuses with the amperage, interrupt, voltage, and speed ratings specified.
Replace the battery as soon as the low battery indicator appears.
Remove the 2 bottom screws by turning counterclockwise.
Remove the 2 top screws.
