Fluke 77 Series III Battery Replacement
Выберете то, что вам нужно
  1. Fluke 77 Series III Battery Replacement, Front Panel: шаг 1, изображение 1 из 1
    • Be sure any test leads are out and the multimeter is off before opening the device.
    • Turn the multimeter so it is display side down.
    • Lift up the back stand of the device by putting your thumb in the curved well at the bottom of the device, so you have access to the two covered screws below.
  2. Fluke 77 Series III Battery Replacement: шаг 2, изображение 1 из 1
    • Use your Phillips #2 Screwdriver to remove the four black 21 mm Phillips #2 screws.
  3. Fluke 77 Series III Battery Replacement: шаг 3, изображение 1 из 2 Fluke 77 Series III Battery Replacement: шаг 3, изображение 2 из 2
    • Turn the Fluke 77 Series III Multimeter back over so that it is display side up.
    • Pry the front panel from the back panel at the seam.
    • If the front panel does not come off easily, move a plastic opening tool along the seam until the panels separate completely.
  4. Fluke 77 Series III Battery Replacement, Battery: шаг 4, изображение 1 из 2 Fluke 77 Series III Battery Replacement, Battery: шаг 4, изображение 2 из 2
    • When doing this next step, make sure to remove the battery slowly, so you don't damage the wires connecting the battery to the device.
    • Locate the 9V battery in the lower right corner of the device.
    • Pull the battery out of its terminal.
  5. Fluke 77 Series III Battery Replacement: шаг 5, изображение 1 из 2 Fluke 77 Series III Battery Replacement: шаг 5, изображение 2 из 2
    • Only pull on the metal snaps and battery. Pulling the cords may damage them.
    • Detach the two metal snaps from the battery.
Заключение
5 участников успешно повторили данное руководство.
Jessica Bombardier Shaw
Участник с: 01/29/14
1 012 Репутация
Автор 7 руководств
Команда
Cal Poly, Team 2-10, Amido Winter 2014 Участник Cal Poly, Team 2-10, Amido Winter 2014
CPSU-AMIDO-W14S2G10
4 членов
Автор 10 руководств
Один комментарий
Easy to understand and all went well!
petruskewichw - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 4
За последние 7 дней: 34
За последние 30 дней: 140
За всё время: 19,291
