FlySky FS-TH9X Joystick Spring Replacement
Выберете то, что вам нужно
  1. FlySky FS-TH9X Joystick Spring Replacement, FlySky FS-TH9X Disassembly: шаг 1, изображение 1 из 1
    • On the back of the remote, you will see 6 5mm Phillips #2 head screws.
    • The six screws on the front of the remote are screws that disconnect the joysticks from the remote and cannot be used to remove the back panel.
  2. FlySky FS-TH9X Joystick Spring Replacement: шаг 2, изображение 1 из 1
    • Using a size two Phillips screwdriver, remove the six 5 mm Phillips #2 head screws
  3. FlySky FS-TH9X Joystick Spring Replacement: шаг 3, изображение 1 из 1
    • Using a pry tool with a little pressure, carefully pull apart the remote to expose the inside.
  4. FlySky FS-TH9X Joystick Spring Replacement: шаг 4, изображение 1 из 1
    • Continue to troubleshooting your device.
  5. FlySky FS-TH9X Joystick Spring Replacement, FlySky FS-TH9X Joystick Spring: шаг 5, изображение 1 из 1
    • Remove screws to open the device and reveal the inside. For this section we will be working with the top half of the remote.
  6. FlySky FS-TH9X Joystick Spring Replacement: шаг 6, изображение 1 из 1
    • Locate this section of your device underneath the joysticks.
  7. FlySky FS-TH9X Joystick Spring Replacement: шаг 7, изображение 1 из 1
    Инструмент, используемый на этом этапе:
    Купить
    • Using a pair of thin tweezers or pliers, remove the spring from its holding hook on the arm first and then from the holding hook on the other end of the spring.
  8. FlySky FS-TH9X Joystick Spring Replacement: шаг 8, изображение 1 из 1
    • Remove the plastic "arm" piece that the spring is connected to and replace the spring or "arm" piece as necessary.
    • It is easier to start attaching the spring to the holding hook attached to the actual remote, then attach the spring the "arm" piece.
  9. FlySky FS-TH9X Joystick Spring Replacement: шаг 9, изображение 1 из 1
    • 1. Replace the spring starting from the bottom holding hook.
    • 2. Slide the plastic "arm" piece back into place.
    • 3. Attach the spring to the arm piece.
    • Once completed it will look like the image shown here. Re-assemble the controller and test the joysticks to make sure everything is working properly again.
Заключение
Еще один человек закончил это руководство.
Heath Soucheck
Участник с: 02/09/23
715 Репутация
Автор 5 руководств
Команда
University of North Texas, Team 3-3, Saru Jimmy Spring 2023 Участник University of North Texas, Team 3-3, Saru Jimmy Spring 2023
UNT-SARU JIMMY-S23S3G3
4 членов
Автор 6 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 5
За всё время: 144
