Fossil Q Marshal Gen 2 Battery Replacement
Выберете то, что вам нужно
  1. Fossil Q Marshal Gen 2 Battery Replacement, Back Cover: шаг 1, изображение 1 из 1
    • Squeeze retaining pins together to release chain from watch body. This can be done by hand or with tweezers.
    • Remove chain from opposing side of watch body.
  2. Fossil Q Marshal Gen 2 Battery Replacement: шаг 2, изображение 1 из 1
    • Use tweezers to grip the notches on the back cover, then unscrew the back cover (counter-clockwise) from the watch housing.
    • There is an actual tool made to remove this back cover, using the right tool may save you from scratching the back of watch with tweezers. The backcover tool can be purchased online, a local jeweler may also be willing to remove it for you.
  3. Fossil Q Marshal Gen 2 Battery Replacement: шаг 3, изображение 1 из 2 Fossil Q Marshal Gen 2 Battery Replacement: шаг 3, изображение 2 из 2
    • Utilize tweezers or a spudger or your fingers to pull the black wire connector from the motherboard.
    • Utilize a spudger to pull the orange connector off of the motherboard.
  4. Fossil Q Marshal Gen 2 Battery Replacement: шаг 4, изображение 1 из 1
    • Utilize tweezers to pull the white battery connector from the motherboard.
  5. Fossil Q Marshal Gen 2 Battery Replacement: шаг 5, изображение 1 из 3 Fossil Q Marshal Gen 2 Battery Replacement: шаг 5, изображение 2 из 3 Fossil Q Marshal Gen 2 Battery Replacement: шаг 5, изображение 3 из 3
    • The internal electronics can now be pulled out of the watch as one unit leaving the screen remaining in the watch housing.
    • Taking the flat end of the spudger, pry it up.
  6. Fossil Q Marshal Gen 2 Battery Replacement, Battery: шаг 6, изображение 1 из 1
    • The battery is secured to the back of the motherboard utilizing a sticky pad. Gently separate the battery from the board while making sure not to put too much stress on the board. This is best done at the location shown.
  7. Fossil Q Marshal Gen 2 Battery Replacement: шаг 7, изображение 1 из 2 Fossil Q Marshal Gen 2 Battery Replacement: шаг 7, изображение 2 из 2
    • Remove battery from plastic housing.
    • Slip wires through large slot in plastic housing to completely remove.
Заключение
16 участников успешно повторили данное руководство.
Clay Walker
Участник с: 11/07/17
752 Репутация
1 руководство автора
Команда
IUPUI, Team S2-G5, Harley Fall 2017 Участник IUPUI, Team S2-G5, Harley Fall 2017
IUPUI-HARLEY-F17S2G5
3 членов
Автор 6 руководств
13 Комментариев
I have read your awesome guide. This is really helpful.
https://powerbank-online.com/reviews/bat...
Ellen Sam - Ответить
thank you, i did it. But now what. i have no idea where to buy the spare part. hahaha. Help Me :(
Rafael “Satriabhi” Atheya - Ответить
I have the exact same battery I need to replace. easy to take out but where do I get the replacement battery??
dustykeith17 - Ответить
Help! I can’t find a replacement battery.
Pedro Pimentel - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 9
За последние 7 дней: 68
За последние 30 дней: 309
За всё время: 40,886
