Введение
This guide shows the general disassembly of the watch. This guide serves as a prerequisite for all guides on internal component replacement . When following this guide be extra careful when undoing wire connections because they can be fragile.
Выберете то, что вам нужно
Squeeze retaining pins together to release chain from watch body. This can be done by hand or with tweezers.
Remove chain from opposing side of watch body.
Use tweezers to grip the notches on the back cover, then unscrew the back cover (counter-clockwise) from the watch housing.
Utilize tweezers or a spudger or your fingers to pull the black wire connector from the motherboard.
Utilize a spudger to pull the orange connector off of the motherboard.
The internal electronics can now be pulled out of the watch as one unit leaving the screen remaining in the watch housing.
Taking the flat end of the spudger, pry it up.
5 участников успешно повторили данное руководство.
4 Комментариев
How do you remove the power switch?
So when i go to reverse the process. It feels like I connect the top screen and top pieces back in and it won't turn on. Any reason why. Sometimes it vibrates them dnt come up.
Thanks, i droped my Fossil Q Founder 2.0 (FTW2119) and this guide help me fix it, i recomend put in the name that also works with mine.
Which battery do I need for this watch. I need a replacement.
