Free Wheelchair Mission GEN 1 Rear Wheel Axle Replacement
Выберете то, что вам нужно
  1. Free Wheelchair Mission GEN 1 Rear Wheel Axle Replacement, Rear Wheel Axle: шаг 1, изображение 1 из 2 Free Wheelchair Mission GEN 1 Rear Wheel Axle Replacement, Rear Wheel Axle: шаг 1, изображение 2 из 2
    • Attach the 19mm socket wrench to the head of the bolt in the middle of the wheel
    • With the other hand use the 19mm crescent wrench to hold the nut in place
    • While holding the 19mm crescent wrench in place, use socket wrench to unscrew the bolt
    • The Free Wheelchair Mission Multi-Purpose Tool can be used in place of the 19mm socket wrench
    • Remove the wheel from the axle
  2. Free Wheelchair Mission GEN 1 Rear Wheel Axle Replacement: шаг 2, изображение 1 из 2 Free Wheelchair Mission GEN 1 Rear Wheel Axle Replacement: шаг 2, изображение 2 из 2
    • Unscrew the nut holding the bolt and wheel together using your hands.
    • It might be necessary to loosen the nut with a 19 mm crescent wrench and the multi purpose tool
    • Repeat step on other wheel
    • Make sure to keep all corresponding nuts and bolts together to prevent mixup when reassembling the axle
  3. Free Wheelchair Mission GEN 1 Rear Wheel Axle Replacement: шаг 3, изображение 1 из 2 Free Wheelchair Mission GEN 1 Rear Wheel Axle Replacement: шаг 3, изображение 2 из 2
    • Locate the two baseplates on the back of the wheelchair holding the axle in place
  4. Free Wheelchair Mission GEN 1 Rear Wheel Axle Replacement: шаг 4, изображение 1 из 3 Free Wheelchair Mission GEN 1 Rear Wheel Axle Replacement: шаг 4, изображение 2 из 3 Free Wheelchair Mission GEN 1 Rear Wheel Axle Replacement: шаг 4, изображение 3 из 3
    • Using the pliers to hold the bolt in place, use the 10mm wrench to remove one bolt from the baseplate.
    • Repeat above step on second bolt
    • Repeat the process on the other baseplate, once one baseplate is loose from the chair and frame,
  5. Free Wheelchair Mission GEN 1 Rear Wheel Axle Replacement: шаг 5, изображение 1 из 3 Free Wheelchair Mission GEN 1 Rear Wheel Axle Replacement: шаг 5, изображение 2 из 3 Free Wheelchair Mission GEN 1 Rear Wheel Axle Replacement: шаг 5, изображение 3 из 3
    • Once both baseplates are loosened from the chair, pull the axle off from the wheelchair
    • The axle should come off easily
    • Slide the baseplates off of the axle
Заключение
To reassemble the axle to the wheelchair, follow these instructions in reverse order.
Еще один человек закончил это руководство.
Mike Sevilla
Участник с: 04/05/13
348 Репутация
Автор 3 руководств
Команда
Cal Poly, Team 14-7, Maness Spring 2013 Участник Cal Poly, Team 14-7, Maness Spring 2013
CPSU-MANESS-S13S14G7
5 членов
Автор 7 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 1
За последние 30 дней: 3
За всё время: 1,489
