Введение
This is a guide for replacing the battery for the Marshall Kilburn Portable Bluetooth Speaker. If the internal battery is broken or worn out, you can replace it with a new one.
Выберете то, что вам нужно
Lay the amp on its side. You should see a small door kept closed with two screws. Turn the amp so the small door faces you.
Using a TR10 Torx Security Screwdriver, remove the two screws from the door.
Remove the door.
Carefully disconnect the battery cord from its socket. Carefully pinch the ends of the rectangular battery cord connector that is connected to the machine and gently pull the rectangular portion away from the machine so that it disconnects.
Один комментарий
Hi, my marshall kilburn will not charge my batterie, the (LL10) is fried on the platina. So i need a external charger for the battery but there are to many out there, which one do i need considering that i have to keep the original connector so i can connect it again to the kilburn socket. Thank you
