Выберете то, что вам нужно
Use a JIS #1 screw driver to remove both 25mm bolts that are attaching the door to the refrigerator.
Remove the damaged hinge. Make sure that you don't lose the bolt that goes into the door.
Remove the door by slowly lifting straight up, put the door off to the side.
2 участников успешно повторили данное руководство.
