Введение
We're going to replace the batteries in a singing doll. This one happens to be Elsa, but this guide is applicable to many plush dolls that sing!
Инструменты
Запчасти
  1. Carefully arrange Elsa's clothing so her body is accessible.
    • Carefully arrange Elsa's clothing so her body is accessible.
    • Find the Voice Module inside the toy's body.
    • Using a seam ripper, open Elsa up near the Voice Module.
  2. Once the seam is ripped, you'll be able to retrieve the Voice Module from inside the toy.
    • Once the seam is ripped, you'll be able to retrieve the Voice Module from inside the toy.
    • The Voice Module is contained inside a small cloth bag -- open it up with the seam ripper.
  3. Carefully pry off the top the Voice Module to expose the electronics inside. Carefully pry off the top the Voice Module to expose the electronics inside.
    • Carefully pry off the top the Voice Module to expose the electronics inside.
  4. Carefully remove the worn LR41 batteries from the Voice Module electronics. Replace with new LR41s, obviously!
    • Carefully remove the worn LR41 batteries from the Voice Module electronics.
    • Replace with new LR41s, obviously!
    • Warning: button batteries are a choking hazard! Dispose of them properly, and away from children.
Заключение
To reassemble Elsa, follow these instructions in reverse order. Except instead of ripping seams, sew them back up.
Be especially careful to sew securely -- loose batteries are a choking hazard.
2 участников успешно повторили данное руководство.
Dom Santangelo
Участник с: 19.09.2016
556 Репутация
Автор 3 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 3
За последние 7 дней: 17
За последние 30 дней: 66
За всё время: 3,445
