Введение
This replacement guide will show you how to access the LCD screen on a Fujifilm FinePix S5100 camera. It is recommended to use a magnetic pad to place the screws on in conjunction with the magnetic tools mentioned above. This is to prevent or minimize the chances of losing or misplacing a screw. The LCD screen is a delicate component so take care and use caution when handling it. Keep it away from hazardous liquids and other objects that may pose a risk to damage to the camera.
Выберете то, что вам нужно
Orient the camera upside down with the lens facing to the left and the battery compartment facing directly toward you.
Open the battery door by pushing down and in the direction of the arrow on the door.
Turn the camera so the screen is facing you and the camera lens is facing away from you.
Remove two 0.9mm Phillips #000 screws from the right side of the camera.
Remove one 0.6mm Phillips #000 screw from the left side of the camera.
Remove two 0.6mm Phillips #000 screws from the bottom side of the camera.
Carefully pull the back cover and separate it from the rest of the camera body.
Carefully flip up the top of the tan colored tab to disconnect the ribbon cable and completely remove the back cover.
Carefully using your hand, grab the LCD screen and pull upward and away from the motherboard.
Carefully using your hand, remove the tan digital tape by disconnecting it from the receiving port.
Remove the entire LCD screen from the motherboard.
Еще один человек закончил это руководство.
