Введение
Outline what you are going to teach someone how to do.
Выберете то, что вам нужно
Remove the flash accessory cap.
Remove the spacer covering the screws under the flash accessory cap.
Remove the 4 screws from the inside of the flash accessory slot.
Pull off the flash accessory slot.
Remove the screw from LCD Screen hinge cover.
Remove the LCD Screen hinge cover.
Remove the 3 screws located on the LCD screen hinge.
Remove the caps from both ends of the LCD screen hinge by lifting them off.
Use a spudger to lift up on the tab, releasing the yellow wire strip.
Use a spudger to lift up on the side tab, releasing the blue wire connection.
