Введение
Outline what you are going to teach someone how to do.
Выберете то, что вам нужно
Use a PH0 screwdriver to remove four screws on the right side, three screws on the bottom, and four on the left side to take off the rear plate.
Remove the three screws holding the LCD screen in place.
Replace with new screen.
Remove the two screws from underneath the flash mechanism.
Remove the two screws placed on the right and left sides of the camera.
Remove the four larger silver plated screws placed on the inside of the lens.
Remove the lens by lifting it up from the cavity.
Once the screws are out, remove the the bracket
Remove speaker with given tweezer tool and replace
2 участников успешно повторили данное руководство.
