Выберете то, что вам нужно
Remove casing part pictured by gently pulling up until casing is fully detached.
Remove the 4 mm screws on the metal plate. Then remove the 4 mm screws on left side of the camera, and remove the two 4mm screws on right side.
Remove the top casing by pulling upwards.
To remove orange tab gently pull on the tab until it is detached from the clamping device on the motherboard.
Remove remaining orange tabs on motherboard. Gently pull on each orange tab until it is free. Make sure all tabs are free (check markers on image).
Use a soldering iron to melt the solder and disconnect the five connections shown.
Remove the motherboard. It should be free of all connections at this point and can be lifted with ease.
Resolder all the connections and wire onto the new motherboard
After given enough time and all the connections on new motherboard are secured, reassemble the camera.
