Введение
In this guide, we will give you step-by-step instructions on how to replace the battery compartment door of the Fujifilm FinePix S4800. This involves taking off the rear plastic case of the camera by removing screws and using a plastic removal tool to separate the rear case from the rest of the camera.
Выберете то, что вам нужно
Rotate the camera so that the label on the base of the camera is facing up.
On the battery compartment door, there is a slider that says "open". Slide it down and push the door to the right to release the door.
Rotate the camera so that the HDMI port is facing up.
Remove the two 5.0 mm JIS #000 screws.
Rotate the camera so that the text "30x superwide 24-720mm" is facing up.
Press the pop-up button highlighted in the picture to release the flash mechanism.
Remove the two 5.0 mm JIS #000 screws highlighted in the picture.
Use a plastic opening tool to separate the rear case from the camera on each of the sides until the panel is completely separated.
Once the rear case is removed, gently separate the battery compartment door from its position.
Еще один человек закончил это руководство.
