Введение
This camera runs on 4 AA batteries. Let's learn how to replace them. This is the simplest maintenance task that you will perform on this camera.
Push the battery chamber latch in the direction of the front of the camera. Keeping tension on the latch, slide the battery chamber cover toward the outside of the camera, opening the battery chamber.
Insert your new batteries, close the battery chamber, and you're done!
3 Комментариев
should there be an indicator led to show the camera is charing ?
should the camera indicate that it is being charged ?
When changing battery the date and time is reset. Is there a backup battery ?
