Fujifilm FinePix S8200 Batteries Replacement
  1. Fujifilm FinePix S8200 Batteries Replacement, Batteries: шаг 1, изображение 1 из 1
    • Turn the camera upside down so you can access the battery chamber.
    • Make sure that the camera is powered off before opening the battery chamber. Not doing so could damage your memory card.
  2. Fujifilm FinePix S8200 Batteries Replacement: шаг 2, изображение 1 из 1
    • Push the battery chamber latch in the direction of the front of the camera. Keeping tension on the latch, slide the battery chamber cover toward the outside of the camera, opening the battery chamber.
  3. Fujifilm FinePix S8200 Batteries Replacement: шаг 3, изображение 1 из 1
    • With the battery chamber open, remove the old batteries.
    • When replacing the batteries, remember that the battery orientation is shown by the + and - marks. Each mark indicates which side of the battery faces up in the chamber.
Заключение
Insert your new batteries, close the battery chamber, and you're done!
Greg Sweeney
Участник с: 01/14/15
137 Репутация
1 руководство автора
Команда
USF Tampa, Team 7-1, Remmell Winter 2015 Участник USF Tampa, Team 7-1, Remmell Winter 2015
USFT-REMMELL-W15S7G1
4 членов
Автор 9 руководств
3 Комментариев
should there be an indicator led to show the camera is charing ?
tony smith - Ответить
should the camera indicate that it is being charged ?
When changing battery the date and time is reset. Is there a backup battery ?
BRIAN STIFF - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 4
За последние 30 дней: 17
За всё время: 1,696
