Введение
A device's motherboard is the center of its operations. Any problems with it will cause the device to malfunction. Depending on the severity of the damage to the motherboard, replacement may be necessary, and this guide will show you how to do that.
Выберете то, что вам нужно
Open the battery chamber and remove the battery.
Pry the front half of the casing from the camera.
Be careful that the sensor cover—the small piece of translucent plastic—doesn't fall out of place. Return it to its original location if it does.
Lift the LCD screen out of the camera.
There is a tab that keeps in place the ribbon that attaches the screen and motherboard. Lift this up using the spudger and disconnect the screen from the motherboard.
Pry the center casing off the camera. This is best done by separating the top and side sections individually.
Peel back the strip of black tape to reveal a red and black wire.
Detach the orange ribbon by gently pulling on it.
Detach the golden ribbon by gently lifting it with the spudger.
The lens should now be free to simply be pushed out of its socket.
The black and red wires that were exposed previously may be in the way of removing the lens and may break. If they do, you will need to solder these wires back into place upon reassembly.
Use tweezers to pull back the plastic covering the top of the camera.
Use tweezers to disconnect both the red and the black wires located next to the flash of the camera.
Use tweezers to disconnect the blue and white wires on the underside of the camera.
