Введение
In order to keep your camera functioning properly, and working battery is vital. A dead or drained battery will prevent the camera from turning on, taking photos, using flash, etc. Replacing the battery or removing for charge is quick and simple.
Выберете то, что вам нужно
Slide the lower silver tab labeled "1"down.
Slide the upper silver tab labeled "2"down. Once the second tab is flipped, the door will spring open.
Simply insert the new battery following the black arrow printed on the battery, matching the orange side of the battery to the orange rubber of the inner battery door.
The orange tab will automatically move to hold the battery in place upon insertion.
2 участников успешно повторили данное руководство.
Один комментарий
Hi Catherine,
Could you direct me to where I could buy a replacement battery door for the XP…exactly the same used in your video.
Many Thanks
Robert
