Введение
If the LCD screen is damaged or malfunctioning, replacing with a new one may solve the issue. Most of the camera has to be taken apart in order to remove the screen.
Выберете то, что вам нужно
Push down on the center button and turn the dial on the side counterclockwise to open the battery compartment.
Remove one Phillips screw with a Phillips head 0 screwdriver
Remove one hex head screw with a hex 1.3 screwdriver bit.
Unscrew seven 4.0 mm screws with a Phillips 00 screwdriver.
Unscrew four 3.0 mm screws with a Phillips 00 screwdriver..
