Введение
A guide on how to take out the many screws located on the inside, metal cover and how to install an LCD.
Выберете то, что вам нужно
Remove the screws from the bottom of the camera using the tri-wing screwdriver.
Three 5.4 mm tri-head screws.
Remove screws from charger side of camera using the Phillips 00 screwdriver.
Two 3.3 mm Phillips #00 screws.
Remove screws from wrist-strap side of camera using the Phillips 00 screwdriver.
Separate the front and back casing using the spudger.
Gently pull apart the two casings.
Pull the back casing away from the camera.
Remove screws from the casing covering the LCD using the Phillips 00 screwdriver.
Remove the fifteen 2.9 mm Phillips #00 screws.
Gently remove the LCD display data cable by gripping the end that is connected to the motherboard and pulling out.
Еще один человек закончил это руководство.
3 Комментариев
Awesome guide! BEST WORK I'VE EVER SEEN ON A REPAIR GUIDE
Shutter button replacement was great too!
Daniel -
