Введение
Use caution when carrying through with procedure, there are components involved than can pinch you when taking it apart.
Выберете то, что вам нужно
Use the Phillips PH00 screwdriver to remove all the 0.5mm screws on the side.
Use the Tri-point Y0 screwdriver to remove the two 0.5mm screws on the horizontal axis.
Remove the other two 0.5mm screws on the bottom with the PH00 screwdriver.
Once you unscrew all of the screws, carefully remove the rear casing.
Detach the ribbon cable by lifting the tab on the connector.
Using the metal spudger, place it in between the leather grip and the black plastic compartment
