Введение
Is the button to take a photo on your Fujifilm Finepix S1800 jammed or broken? This guide will show you step by step on how to replace the jammed or broken button.
Выберете то, что вам нужно
Unscrew the four 4mm screws on the left-hand side of the camera with the JIS #1 screwdriver.
Unscrew the four 4mm screws on the right-hand side of the camera with the JIS #1 screwdriver.
Unscrew the three 4mm screws on the bottom of the camera with the JIS #1 screwdriver.
Take the plastic opening tool and place it in the space between the top of the screen and the top of the camera.
The cover will pop out.
Remove the three 2 mm screws from the back cover plate with the Phillips #000 screwdriver.
Gently lift the back cover away from the device.
Lift the flash.
Remove the two 4 mm screws from the top of the camera with the JIS #1 screwdriver.
Remove the 4 mm screws from the left and right sides of the camera with the JIS #1 screwdriver.
Remove the two 2 mm screws underneath the plate with the Phillips #000 screwdriver.
2 участников успешно повторили данное руководство.
