Выберете то, что вам нужно
Untie the wrist strap by loosening the small black end of it, and pulling the large part out of the loop it makes which holds it in place.
Turn the camera on its side and take off the battery cover by pulling down while putting pressure onto the cover.
Remove both AA batteries.
Turn the camera to its back side and push down on the clip at the top of the film cover and remove film.
Remove the six shell screws highlighted using a Philips #00 screwdriver.
Remove the shroud for the film printer. Carefully pry around the edge of the shroud until the part comes loose.
Carefully pry around the lens shroud in a circular motion in order to remove it.
Gently pry along the shell seam while tracing the seam along all sides of the camera. Take the front shell off the camera once the shell is released.
Remove the battery slot by unscrewing the two highlighted screws. Once loose, remove the piece to reveal the capacitor.
Heat the soldering iron up to 600°F and firmly hold it onto the soldered contacts.
Replace the flash capacitor by de-soldering the highlighted contacts.
Use a soldering wick or a vacuum pump to absorb the melted solder and remove capacitor once the wires are separated from the contacts.
2 человек успешно провели ремонт по этому руководству.
