Введение
Take caution as to not touch both ends of the capacitor, or any exposed ends of wire that are connected to such. The capacitor stores a large amount of charge, and could shock you. You will need a soldering station and something to remove old solder, such as a desoldering pump or a solder wick.
Выберете то, что вам нужно
Remove the six 4.5 mm #00 Phillips screws from the bottom, left, and right sides.
Use a spudger to remove the film slot guard on the top of the camera.
Remove the one 4.5 mm #00 Phillips screw under the slot guard.
Press the release tab on the back of the camera to open the film compartment.
Remove the film cartridge within this compartment.
Use a plastic opening tool to help pry the front and back shells apart.
With the camera facing down, remove only the back shell.
Remove the four 4.5 mm screws inside the battery holder with a long #00 Phillips screwdriver.
Gently pull on the battery holder to remove it from the case, exposing the capacitor.
Pull up on the backside of the capacitor to remove it from the battery holder.
