Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Locate the two clips on the bottom of the computer that support the battery.
Using your fingers, push the clips inward and then upward.
Lift the battery out of the computer.
Use a spudger to lift the back of the hinge cover on the left and right sides of the computer.
Lay the computer flat on a stable surface with the monitor pointing away from you.
Disconnect the ribbon cable from the motherboard and remove the hinge cover from the computer.
Use a spudger to release the ribbon cable from the motherboard.
After the ribbon has been detached, carefully remove the keyboard.
Remove the following screws, all labeled "3."
Two 8.63mm screws.
One 7.65mm screw.
One 5.74mm screw.
Remove the following screw, labeled "15."
One 17.81mm screw.
Remove the screws from the bottom of the hinge as shown in the image.
Use a spudger to detach and remove cables from the motherboard.
Hold down the body of the computer by placing your hands in the pictured positions. Then, lift the display from the body.
Remove screws from bottom of laptop as shown in the picture.
Lift the palm rest cover from the base of the laptop.
You may use spudger if needed, lift from the front corners as shown.
Great job! You have successfully removed the old palm rest cover.
