Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Выберете то, что вам нужно
Locate the two clips on the bottom of the computer that support the battery.
Using your fingers, push the clips inward and then upward.
Lift the battery out of the computer.
Use a spudger to lift the back of the hinge cover on the left and right sides of the computer.
Lay the computer flat on a stable surface with the monitor pointing away from you.
Disconnect the ribbon cable from the motherboard and remove the hinge cover from the computer.
Remove the following screws, all labeled "3."
Two 8.63mm screws.
One 7.65mm screw.
One 5.74mm screw.
Remove the following screw, labeled "15."
One 17.81mm screw.
Hold down the body of the computer by placing your hands in the pictured positions. Then, lift the display from the body.
Lift the palm rest cover from the base of the laptop.
You may use spudger if needed, lift from the front corners as shown.
Push securing clips outward, the wireless module will pop out.
Remove the wireless module.
