Введение
RAM is essential for your Fujtsu Lifebook Model a6110 laptop’s speed and when it begins to slow down or crash without warning, you will need to remove and replace your Random Access Memory (RAM). Whether you are replacing or upgrading your system's memory, this easy to use guide demonstrates the process in six steps.
Выберете то, что вам нужно
Flip your laptop so that the bottom of the laptop is facing up and the hinges of the screen are closest to you.
To remove the battery, place your fingers underneath the two clips and simultaneously lift them up while pulling the cover towards you.
The RAM compartment will be located near the bottom-left corner of your lifebook. The compartment is behind the cover held in place by a 6 mm screw.
Using a Phillips #1 screwdriver, remove the 6 mm screw from the RAM compartment on the bottom-left corner of the rear cover.
Simultaneously pull each metal and plastic clip away from the center of the RAM stick.
