Введение
Is your headphone jack not working or possibly damaged? Well you’re in luck, this guide will show you the step-by-step instructions on how to replace your headphone jack.
Выберете то, что вам нужно
Remove the white sticker covering the screws (if applicable).
Use the PH1 screwdriver to remove the four 2 mm screws from the the backside of the device.
Insert the plastic opening tool along the seam of the back case.
Gently slide the plastic opening tool along the entire seam popping the clips free.
Carefully lift the back case and remove the smartcard ribbon from the motherboard.
Remove the ten 3mm screws with a PH00 screwdriver from the shield.
Lift the shield away from the device and remove the fingerprint scanner's ribbon from the motherboard.
Disconnect upper peripheral ribbons from motherboard.
Disconnect left peripheral ribbon from motherboard.
Now use an ESD-safe spudger to gently pry up the silver piece and flip it over. Be sure not to remove this piece completely!
Use an ESD-safe spudger to gently push the yellow piece out from the white cradle.
When removing the headphone jack, simply use your fingers to pull out the white and black piece altogether.
Еще один человек закончил это руководство.
