Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Remove battery by pushing down the latch lock and sliding the latch to the left as shown.
With your finger nail pry the battery off at the indent for the latch lock.
With battery removed take out the fan dust catcher (indicated by the red rectangle).
Using PH1 Philips screwdriver bit (indicated in third picture) remove the screws identified by the red circles.
Remove the RAM, fan, and hard drive covers.
Remove the hard drive. Now everything should look like picture two.
Remove expansion bay device. (battery, disk drive, weight saver)
Remove stylus pen.
Using PH1 bit remove the five indicated screws in the battery well.
Remove RAM.
Unplug system fan. (also indicated in picture two)
Using PH1 bit remove the 14 indicated screws on the base of the laptop, indicated by picture three.
Next we are going to remove the keyboard top, this gives access to the inside of the laptop.
There are three tabs on the keyboard cover that keep it attached. (indicated by picture one)
Picture two you can see them disconnected, using a finger nail or electronic case opener gently release the tab by applying outward force on the black plastic part of the case.
After unlatching the three tabs from the last step you should be able to remove the keyboard trim underneath the screen.
Apply gentle force around the edges to unhook any tabs and it should come right out.
With the tabs unlatched and the keyboard trim removed you should be able to easily pivot the keyboard cover as shown.
Using a fingernail or spudger disconnect the trackpad/keyboard data cable, then set aside the keyboard cover.
Remove the data ribbon cable indicated.
Very gently using a fingernail or small spudger lift up on the dark plastic part of the ZIF connectors. (illustrated in pictures two and three)
After unlatching both locks you can lift up on the cable and set it to the side.
Next we are removing the EMI shield attached to the motherbaord.
Shown in picture two if you release this one tab the cover pivots right off.
Next we are removing the USB and audio board. The blue circle is indicated where the only screw is, use your trust PH1 bit.
Use a fingernail or spudger to lift up the board as shown before pulling it out.
Remove the wifi antennas. (picture one)
Remove the display, touch, and backlight connectors from the motherboard as indicated in pictures two and three.
After disconnecting the display connections we are ready to unscrew the display mount screws.
Use the trusty PH1 bit to take out the 4 screws indicated in picture one.
You can now lift out the display assembly, 2 antennas and 3 cables will be attached to it. Set it aside.
Remove the 9 screws indicated in picture 1 with PH1 bit.
Pivot the motherboard up from the front as indicated in picture 2.
Next we must disconnect the power plug from the motherboard before we can remove it.
Now you can remove the motherboard and set it aside on an anti-static bag or surface.
Heatsink is very inadequate, which is why this laptop gets noticeably high temperatures.
4 Комментариев
Thanks for posting this..
Thank you! Very helpful
Well done! Thank you!
