Введение
The quality of air in our homes can directly and significantly impact our overall health. Keeping a functioning air purifier can help to pull any pollutants that might be causing you harm, out of the air. In this guide, you will learn how to disassemble and replace the ionizer wires in a Fulminare H13 True HEPA Air Purifier.
The ionizer wire is what removes small particles from the air and "clean" the air using negative ions. If the wire isn't working, the air going through won't be cleaned. If the ionizer wires in your Fulminare H13 True HEPA Air Purifier fail, follow this guide to replace them.
Before starting this repair, turn off your unit and unplug it from the power outlet.
Выберете то, что вам нужно
Turn off the unit and unplug it.
Twist the lid counterclockwise and lift it up to reveal the black filter.
Using a Phillips screwdriver, remove the two 2 mm screws holding the filter in place.
Using a Phillips screwdriver, remove the four 3.2 mm screws that secure the fan.
Lift the top clips off and pull the fan down and out.
Use a Phillips screwdriver to remove the two 1.25 mm screws holding the motherboard in place.
Pull the cables away from the connectors in the same direction as the individual wires are running.
