Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Unscrew a total of 6 4.45 mm phillips head screws using a #00 phillips head screwdriver.
There are 2 screws on the left side (when looking at the front of the camera).
There are 3 screws on the bottom
There is 1 screw on the right side
Turn to the bottom of the camera.
Open the memory card cover by sliding the "CARD/BATT." button up, and then pulling the cover to the left.
This is what the SD card/battery compartment looks like when opened.
Remove one 4.45mm phillips head screw from the SD card/battery compartment using a #00 phillips head screwdriver.
The camera should look like this once the front cover is removed.
Start from the battery compartment and remove the back cover.
Remove the connecting ribbon from the body of the camera using a pair of tweezers.
Once the ribbon connecting the back cover is removed, the back of the camera body should look like this.
Remove 2 4.35mm phillips head screws from around the LCD screen using a #00 phillips head screwdriver.
Loosen the black ribbon clamp using an iPod opening tool
Release the LCD screen by removing the ribbon from the body of the camera.
Unscrew 2 3.35mm phillips head screw from the face of the function key motherboard using a #00 phillips head screwdriver.
Release the black ribbon clamp attached to the back of the motherboard using an iPod opening tool to lift the clamp.
Remove the ribbon connecting the function key motherboard from the body of the camera using tweezers.
The function key motherboard has the SD card reader attached to the back. The motherboard and SD card combination should be replaced.
Еще один человек закончил это руководство.
