Введение
This guide will show you how to replace the microphone and speaker assembly on your Furbo Dog Camera. (Furbo:2). Replacing this component may fix any issues that you are having with your sound quality that could not be fixed by troubleshooting efforts. This guide shows you how to remove the hardware containing the microphone and speaker
Выберете то, что вам нужно
Rotate your Furbo so that the bottom faces you.
Remove the rubber caps to reveal the four screws on the bottom of the Furbo.
Инструмент, используемый на этом этапе:Flathead 3/32" or 2.5 mm Screwdriver$5.49
Use a 2.5 mm Flathead screwdriver to remove the four 5 mm screws from the bottom of the Furbo.
Use a 2.5 mm Flathead screwdriver to remove the single 5 mm screw under the silver sticker.
Rotate your Furbo so that the side is facing towards you.
Use an opening tool to separate the two plastic coverings.
Once you have separated the two plastic coverings, remove one side by pulling on it and carefully separating it from the adhesive.
Carefully remove the copper foiling that surrounds the camera hardware.
Use a Phillips #000 screwdriver to remove the 2.5 mm screws at the top of the camera hardware.
Use a Phillips #000 screwdriver to remove the 0.4 mm screws that attach the camera to the Furbo case.
Remove the microphone and speaker component and replace with new part
