Введение
The purpose of the RAM are for quick and temporary memory slots, this model specifically has two RAM that are blue in color. Before attempting to do a replacement, make sure your device is powered off and make sure to read through the guide first before jumping straight into a repair. Safety is always first!
Выберете то, что вам нужно
Before doing anything, first make sure the laptop is turned off and flipped over. In this position your laptop's bottom side should be facing up.
Using a nylon spudger or your fingers, push down on the battery clip to release the battery.
Finally, remove the battery by detaching it from the laptop casing. Once removed, set the battery aside and insert the new battery.
Locate the casing that protects the RAM modules, wireless card, and hard drive.
With the PH1 head from the tool kit and the adjustable screwdriver, remove the 2 M3x5.0mm screws on the casing to get to the RAM modules.
On each RAM module there are two silver latches holding them in place
Release the latches to be able to remove the RAM module.
To reassemble your device, please follow these instructions in reverse order.
