Введение
If your GEHEN Portable Clip-On Fan no longer turns on or the fan doesn't charge anymore, perhaps it is time to replace the battery. Over time, lithium batteries can begin to lose their efficiency or even stop working altogether. A battery change is needed despite the remaining components being fully functional inside the GEHEN Portable Clip-On Fan. Using a couple of tools, we will go over the steps necessary to replace the battery to extend the shelf life of the GEHEN Portable Clip-On Fan. Along with changing the battery, we will also go over how to dispose of the old batteries properly.
Warning: If one or both of the batteries inside the GEHEN Portable Clip-On Fan are visibly swollen when replacing, take the necessary precautions for dealing with a swollen battery as they can be dangerous and potentially cause a fire. For more information on how to deal with a swollen battery, take a look at this blog post on What to Do With a Swollen iPhone Battery.
Выберете то, что вам нужно
Use a Phillips #3 screwdriver to remove the two 20 mm screws from the back panel of the fan.
Squeeze the tab against the power cable connector, and pull the connector straight up from the socket.
Use tin snips to carefully remove the thin piece of metal that connects the ends of the two batteries.
Repeat this step on both ends.
Take the new batteries and reattach the connector.
Use the tape cover that was set aside earlier and apply one on each end of the batteries.
Place the battery pack back into the holder on the back panel.
Once the back panel has been fastened, ensure that the fan works by pressing the button repeatedly until all the LEDs turn on.
