Введение
Brakes are some of the most important components on any sort of transportation device or vehicle, whether it's a bike, car, or scooter. Without brakes, coming to a full stop would be near impossible. For something like a scooter, needing to brake rapidly is extremely important as you have nothing to protect you. This guide will teach you how to successfully replace the brake caliper on your GOTRAX GMAX Ultra electric scooter. This scooter can go up to 30k/h so keeping your brakes in good working condition is necessary. Note that you will need a replacement brake caliper beforehand so contact the manufacturer for the required part prior to beginning the repair.
Выберете то, что вам нужно
Use the 5mm hex key to remove the 16mm screw holding the brake cable in place.
Next, use the 4 mm Hex key to remove the 14 mm screw on the side of the caliper that holds the housing to the brake pads.
Use the 4 mm Hex key to remove two 22 mm screws that hold the caliper to the scooter body.
To reassemble your device, simply follow these instructions in reverse order. You may have to adjust the caliper and brake cable in order for the disc to spin smoothly.
Еще один человек закончил это руководство.
