Введение
If the device does not charge, the problem is with:
- Charging board
- Main flex cable
- Motherboard
In this manual, we will show you how to fix your device if the problem is with the Motherboard FPC connector.
Выберете то, что вам нужно
Видео обзор
Samsung Galaxy A71 does not charge.
Connect the charger and press the phone as per the second image.
Warm the device to soften the adhesive.
Use plastic tools and isopropyl alcohol to separate the back cover.
Remove all silver Phillips screws.
Remove the SIM Tray.
Use a suitable plastic tool to remove the middle frame.
Disconnect the battery.
Connect the charger and measure the voltage at the two end pins. It should be ~5V.
If not, search for the problem at the charging board or the main flex cable.
Remove the black tape stuck around the connector.
Use a soldering iron, flux and tin wire to resolder the first pin of the FPC connector.
8 участников успешно повторили данное руководство.
Один комментарий
Good morning. My A71 screen is blinking on and off black screen. What can I do to fix it? Also when I'm attempting to type in any chat I have to press down really hard to get the letters on the screen? As my phone heats up it goes black,if I'm in a room that has AC units it remains on for a longer period of time.
