Введение
This guide will give step by step instructions on how to remove and replace an existing battery in the Samsung Galaxy Tab S 10.5.
Запчасти
Place the plastic opening tool into the SD card slot or charge port.
Try in an upward motion until you see a separation between the tablet and back cover.
Work around the entire device by sliding the plastic opening tool around the rim.
Using tweezers, peel back the green tape from the ZIF connectors on the two black ribbon cables.
Use a plastic opening tool to lift up the plastic clips on the ZIF connectors.
Place the plastic opening tool between the frame and battery.
Move the plastic opening tool in a downward motion, away from the battery to bring the battery out of the device.
77 участников успешно повторили данное руководство.
Комментариев: 18
where is a good place to buy a replacement battery?
Artículo muy positivo: pasos muy bien detallados. Me ha resultado fácil la el cambio de batería. Gracias por tu colaboración.
Bought mine off of ebay
