Game Boy Advance Logic Board Replacement
Выберете то, что вам нужно
  1. Game Boy Advance Logic Board Replacement, Remove the Battery Cover/Batteries: шаг 1, изображение 1 из 3 Game Boy Advance Logic Board Replacement, Remove the Battery Cover/Batteries: шаг 1, изображение 2 из 3 Game Boy Advance Logic Board Replacement, Remove the Battery Cover/Batteries: шаг 1, изображение 3 из 3
    • Take the battery cover off by releasing the locking tab and hinging the cover away. Remove the batteries inside the cover
    • Do not forget to remove the batteries! This applies to working with any electronic device as working with live electricity may damage the device or cause malfunctions
  2. Game Boy Advance Logic Board Replacement, Unscrew the Back Panel: шаг 2, изображение 1 из 2 Game Boy Advance Logic Board Replacement, Unscrew the Back Panel: шаг 2, изображение 2 из 2
    • Remove the six back panel screws using a Tri-wing Screwdriver.
    • Remove bottom back panel screw with a Phillips #1 screw driver. (Image #2)
  3. Game Boy Advance Logic Board Replacement, Remove the Back Panel: шаг 3, изображение 1 из 1
    • Remove the back panel by pulling away with one hand and the front secured in the other hand.
    • Removal of the back panel may cause shoulder buttons and side panels to come loose and fall off.
  4. Game Boy Advance Logic Board Replacement, Remove Triggers: шаг 4, изображение 1 из 2 Game Boy Advance Logic Board Replacement, Remove Triggers: шаг 4, изображение 2 из 2
    • Remove left and right triggers by lifting and pulling them away from the system.
    • Do the same for side panels
    • For finicky or jammed triggers only! Adjust and correct triggers and reassemble. Most jammed triggers are caused by buttons misplaced or jammed in its enclosure.
  5. Game Boy Advance Logic Board Replacement, Remove the On/Off Switch: шаг 5, изображение 1 из 1
    • Remove the gray On/Off Switch by pulling up and away from the unit. Replace with another switch if necessary.
  6. Game Boy Advance Logic Board Replacement, Buttons and LCD Screen: шаг 6, изображение 1 из 1
    • Remove the three screws on the circuit board with a Phillips #1 screw driver.
  7. Game Boy Advance Logic Board Replacement: шаг 7, изображение 1 из 2 Game Boy Advance Logic Board Replacement: шаг 7, изображение 2 из 2
    • Pull circuit board away from the front panel by pulling up at the bottom of the circuit board, keeping the top ribbon still connected.
    • Handle with care! The ribbon connecting the circuit board to the LCD screen can easily be damaged and will require replacement if broken.
  8. Game Boy Advance Logic Board Replacement, Buttons: шаг 8, изображение 1 из 3 Game Boy Advance Logic Board Replacement, Buttons: шаг 8, изображение 2 из 3 Game Boy Advance Logic Board Replacement, Buttons: шаг 8, изображение 3 из 3
    • Remove the rubber button pads from their pockets.
    • Remove the plastic buttons and the D-pad from beneath the rubber pads with tweezers or by hand.
  9. Game Boy Advance Logic Board Replacement, Logic Board: шаг 9, изображение 1 из 3 Game Boy Advance Logic Board Replacement, Logic Board: шаг 9, изображение 2 из 3 Game Boy Advance Logic Board Replacement, Logic Board: шаг 9, изображение 3 из 3
    • Using the tweezers, gently pull the ribbon from the logic board.
Заключение
6 участников успешно повторили данное руководство.
Jay Aricheta
Участник с: 01/20/10
319 Репутация
1 руководство автора
Команда
Cal Poly, Team 16-29, Maness Winter 2010 Участник Cal Poly, Team 16-29, Maness Winter 2010
CPSU-MANESS-W10S16G29
5 членов
Автор 61 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 6
За последние 7 дней: 36
За последние 30 дней: 151
За всё время: 16,588
