Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Take the battery cover off by releasing the locking tab and hinging the cover away. Remove the batteries inside the cover
Remove the six back panel screws using a Tri-wing Screwdriver.
Remove bottom back panel screw with a Phillips #1 screw driver. (Image #2)
Remove the back panel by pulling away with one hand and the front secured in the other hand.
Remove left and right triggers by lifting and pulling them away from the system.
Do the same for side panels
Remove the gray On/Off Switch by pulling up and away from the unit. Replace with another switch if necessary.
Remove the three screws on the circuit board with a Phillips #1 screw driver.
Pull circuit board away from the front panel by pulling up at the bottom of the circuit board, keeping the top ribbon still connected.
Инструмент, используемый на этом этапе:Tweezers$4.99-
Remove the rubber button pads from their pockets.
Remove the plastic buttons and the D-pad from beneath the rubber pads with tweezers or by hand.
Using the tweezers, gently pull the ribbon from the logic board.
6 участников успешно повторили данное руководство.
