Введение
Use this repair guide when debris needs to be cleared from the On/Off switch or it needs to be replaced.
Инструменты
Запчасти
Детали не указаны.
Take the battery cover off by releasing the locking tab and hinging the cover away.
Remove the back panel by pulling away with one hand and the front secured in the other hand.
Remove left and right triggers by lifting and pulling them away from the system.
Do the same for side panels
Remove the gray On/Off Switch by pulling up and away from the unit. Replace with another switch if necessary.
4 участников успешно повторили данное руководство.
