Введение
Use this repair guide to replace the screen if it has been damaged.
Инструменты
Запчасти
Детали не указаны.
Видео обзор
Remove the back battery cover by pinching down on the tab and pulling outward.
Remove the back panel by pulling away with one hand and the front secured in the other hand.
Remove left and right triggers by lifting and pulling them away from the system.
Do the same for side panels.
Remove the gray On/Off Switch by pulling up and away from the unit. Replace with another switch if necessary.
Pull circuit board away from the front panel by pulling up at the bottom of the circuit board, keeping the top ribbon still connected.
Remove the rubber button pads from their pockets.
Remove the plastic buttons and the D-pad from beneath the rubber pads with tweezers or by hand.
Use a spudger/tweezers/fingernail to unlatch the LCD ribbon port by pulling the grey tabs on the sides upwards (towards the top edge of the PCB).
Once the LCD ribbon port has been unlatched, the LCD ribbon should very easily slide out and can be removed with zero force using fingers or tweezers.
Use the spudger to lift the screen from the front panel. Place the spudger in the space directly left of the D-pad.
14 участников успешно повторили данное руководство.
Комментариев: 5
Doesn't say where you can get new screen !!!!??
Doesn't say where to get screen from !!!??
Do this with the Game Boy Advance SP please!
It does not say where you can get a new screen
DONT DO THIS LIKE THAT!!!. The area of the screen in the space beside the D-pad is the only area where the LCD glass is completely exposed. It’s Literaly the WORST place to apply pressure, 99% chances for the LCD to break. There is a notch on the top right corner and another under the ribbon cable. Making your way from the top right to the left is far more safe.
