Game Boy Advance Shoulder Button and Side Panels Replacement
Выберете то, что вам нужно
  1. Game Boy Advance Shoulder Button and Side Panels Replacement, Remove the Battery Cover/Batteries: шаг 1, изображение 1 из 3 Game Boy Advance Shoulder Button and Side Panels Replacement, Remove the Battery Cover/Batteries: шаг 1, изображение 2 из 3 Game Boy Advance Shoulder Button and Side Panels Replacement, Remove the Battery Cover/Batteries: шаг 1, изображение 3 из 3
    • Take the battery cover off by releasing the locking tab and hinging the cover away. Remove the batteries inside the cover
    • Do not forget to remove the batteries! This applies to working with any electronic device as working with live electricity may damage the device or cause malfunctions
  2. Game Boy Advance Shoulder Button and Side Panels Replacement, Unscrew the Back Panel: шаг 2, изображение 1 из 2 Game Boy Advance Shoulder Button and Side Panels Replacement, Unscrew the Back Panel: шаг 2, изображение 2 из 2
    • Remove the six back panel screws using a Tri-wing Screwdriver.
    • Remove bottom back panel screw with a Phillips #1 screw driver. (Image #2)
  3. Game Boy Advance Shoulder Button and Side Panels Replacement, Remove the Back Panel: шаг 3, изображение 1 из 1
    • Remove the back panel by pulling away with one hand and the front secured in the other hand.
    • Removal of the back panel may cause shoulder buttons and side panels to come loose and fall off.
  4. Game Boy Advance Shoulder Button and Side Panels Replacement, Remove Triggers: шаг 4, изображение 1 из 2 Game Boy Advance Shoulder Button and Side Panels Replacement, Remove Triggers: шаг 4, изображение 2 из 2
    • Remove left and right triggers by lifting and pulling them away from the system.
    • Do the same for side panels
    • For finicky or jammed triggers only! Adjust and correct triggers and reassemble. Most jammed triggers are caused by buttons misplaced or jammed in its enclosure.
    my side pannel on the right is a little loose how do i fix it
    Mark - Ответить
Заключение
4 участников успешно повторили данное руководство.
Aldo Corona
Участник с: 01/25/10
799 Репутация
Автор 6 руководств
Команда
Cal Poly, Team 16-29, Maness Winter 2010 Участник Cal Poly, Team 16-29, Maness Winter 2010
CPSU-MANESS-W10S16G29
5 членов
Автор 61 руководств
Один комментарий
i need help th e side pannels loose
Mark - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 14
За последние 30 дней: 58
За всё время: 7,945
