Game Boy Batteries Replacement
Выберете то, что вам нужно
    1. Game Boy Batteries Replacement, Batteries: шаг 1, изображение 1 из 2 Game Boy Batteries Replacement, Batteries: шаг 1, изображение 2 из 2
      • Switch your Game Boy off and remove the cartridge.
      Спросите у FixBot
      Добавить комментарий
    2. Game Boy Batteries Replacement: шаг 2, изображение 1 из 3 Game Boy Batteries Replacement: шаг 2, изображение 2 из 3 Game Boy Batteries Replacement: шаг 2, изображение 3 из 3
      • Use a fingernail (or small coin) to push down on the battery door latch and remove the battery door.
      • The release latch is a plastic spring clip. If your Game Boy is getting on in years, be careful as the plastic may be brittle.
      • When you're replacing the cover, be sure to get its two plastic tabs into the slots in the bottom of the battery compartment before pushing the cover back in place.
      Спросите у FixBot
    3. Game Boy Batteries Replacement: шаг 3, изображение 1 из 2 Game Boy Batteries Replacement: шаг 3, изображение 2 из 2
      • Use a fingernail to pry each battery outward from the positive (+) terminal to remove them.
      • Dispose of used batteries properly!
      • Remove the batteries from your Game Boy before storing it for more than a month or so.
      Спросите у FixBot
Заключение
27 человек успешно провели ремонт по этому руководству.
Andrew Tramposch
Участник с: 06/24/10
2 378 Репутация
Автор 6 руководств
Команда
Cal Poly, Team 3-2, Johann Summer 2010 Участник Cal Poly, Team 3-2, Johann Summer 2010
CPSU-JOHANN-R10S3G2
3 членов
Автор 67 руководств
5 Комментарии к руководству
This was a very helpful guide. I had no idea how to replace the batteries for my GameBoy, but thanks to this amazing and helpful guide, I was able to do so. The only issue that I have with this guide is that it did not explain how to properly dispose the used batteries. I ended up soaking them in gasoline and lighting them on fire because the colors look super pretty. Don’t breath the smoke though! I’m pretty sure the smoke is toxic?
Mentat - Ответить Поделиться
I have struggled with this for 20 years. Thank you.
Igor Kolosha - Ответить Поделиться
My problem was that I removed four batteries from my Game Boy Classic but only inserted three new ones. It didn’t work. An expert told me to also insert four new ones, it worked.
Akula - Ответить Поделиться
Awesome! I finally know how!
Ethan Sligar - Ответить Поделиться
My wife came back because of this tutorial.
Mia Cipollone - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 7
За последние 7 дней: 37
За последние 30 дней: 138
За всё время: 25,846
