Game Boy Color Buttons Replacement
Выберете то, что вам нужно
  1. Game Boy Color Buttons Replacement, Battery: шаг 1, изображение 1 из 2 Game Boy Color Buttons Replacement, Battery: шаг 1, изображение 2 из 2
    • Locate the battery compartment on the back of the Game Boy Color.
    • Push down on the tab and hinge the cover downwards and outwards to remove the battery cover.
  2. Game Boy Color Buttons Replacement: шаг 2, изображение 1 из 1
    • Remove the batteries from the battery compartment.
  3. Game Boy Color Buttons Replacement, Back Housing: шаг 3, изображение 1 из 1
    • Using a Y1 screwdriver, remove the six screws on the back of the device as pictured. The bottom two screws are located inside of the battery compartment.
    I did this with a Y0 bit. It works if you are careful. I wouldn't recommend it on other consoles but for this tiny thing, it works.
    phnome - Ответить
    The guide says a Y0 is needed. Is it a Y1 or Y0?
    Trav - Ответить
  4. Game Boy Color Buttons Replacement: шаг 4, изображение 1 из 2 Game Boy Color Buttons Replacement: шаг 4, изображение 2 из 2
    • Gently lift and separate the back housing from the rest of the device. Now you've got the back housing out!
  5. Game Boy Color Buttons Replacement, LCD Ribbon Cable: шаг 5, изображение 1 из 1
    • Push up on the tabs on either side of the ribbon with a spudger.
  6. Game Boy Color Buttons Replacement: шаг 6, изображение 1 из 1
    • Gently remove the ribbon cable from the port
  7. Game Boy Color Buttons Replacement, Motherboard: шаг 7, изображение 1 из 2 Game Boy Color Buttons Replacement, Motherboard: шаг 7, изображение 2 из 2
    • Using the Phillips #1 screwdriver, remove the 3 screws shown in the picture.
    It’s not mentioned here, but be sure to unplug the LCD flex cable at the top of the motherboard before removing the motherboard. To do so, gently press the clips on either side of the receptacle toward the top of the Game Boy. When they are both pressed up, the orange cable will slide freely out
    Ben Perkins - Ответить
    Thanks Ben. That's a very good point. Just ripping it out will cost you a couple bucks, not to mention your Gameboy will not work until you replace that ribbon cable.
    Chris Pavlik - Ответить
  8. Game Boy Color Buttons Replacement: шаг 8, изображение 1 из 1
    • Gently lift the motherboard from the front housing.
  9. Game Boy Color Buttons Replacement, Buttons: шаг 9, изображение 1 из 1
    • Remove the rubber backing on each button grouping.
  10. Game Boy Color Buttons Replacement: шаг 10, изображение 1 из 1
    • Remove the original buttons from the housing.
Заключение
24 участников успешно повторили данное руководство.
Nick Katsantones
Участник с: 01/18/13
946 Репутация
Автор 4 руководств
Команда
Cal Poly, Team 19-47, Regan Winter 2013 Участник Cal Poly, Team 19-47, Regan Winter 2013
CPSU-REGAN-W13S19G47
4 членов
Автор 56 руководств
2 Комментариев
Thank you for your information on repair of my color game boy.
just two things.
1. I had a hard time with the removal of the screws. Any tip on that would be helpful.
2. Where can I purchase replacement parts?
Thanks again for all of your help.
Ray Blasko
raymondblasko - Ответить
In the tools needed it states Y0 screwdriver, but in step 3 it says Y1 which is not the same. Which one is the correct size?
blogcraft - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 13
За последние 7 дней: 92
За последние 30 дней: 276
За всё время: 27,794
