Введение
Removing the ribbon cable provides unhindered access to the inner workings of the Game Boy Color.
Инструменты
Запчасти
Детали не указаны.
Locate the battery compartment on the back of the Game Boy Color.
Push down on the tab and hinge the cover downwards and outwards to remove the battery cover.
Using a Y1 screwdriver, remove the six screws on the back of the device as pictured. The bottom two screws are located inside of the battery compartment.
Gently lift and separate the back housing from the rest of the device. Now you've got the back housing out!
Push up on the tabs on either side of the ribbon with a spudger.
9 участников успешно повторили данное руководство.
