Game Boy Color Speaker Replacement
Выберете то, что вам нужно
  1. Game Boy Color Speaker Replacement, Battery: шаг 1, изображение 1 из 3 Game Boy Color Speaker Replacement, Battery: шаг 1, изображение 2 из 3 Game Boy Color Speaker Replacement, Battery: шаг 1, изображение 3 из 3
    • Remove any games in the system before beginning.
    • Press up on the battery holder tab on the back to lift it up and remove it
  2. Game Boy Color Speaker Replacement, Removing the back shell: шаг 2, изображение 1 из 2 Game Boy Color Speaker Replacement, Removing the back shell: шаг 2, изображение 2 из 2
    • Using a Y1 screwdriver, remove the six screws on the back of the device.
  3. Game Boy Color Speaker Replacement, Removing the motherboard: шаг 3, изображение 1 из 1
    • When reassembling, make sure to align the power switch with the corresponding piece of plastic inside the shell. If not aligned it will stop you from screwing it back together and will break if force is applied.
    • Don't yet unsolder the speaker, as you'll be unable to remove it until the motherboard comes off.
    • Remove the 3 PH0 Phillips screws near the bottom of the device.
  4. Game Boy Color Speaker Replacement, Display Ribbon Cable: шаг 4, изображение 1 из 3 Game Boy Color Speaker Replacement, Display Ribbon Cable: шаг 4, изображение 2 из 3 Game Boy Color Speaker Replacement, Display Ribbon Cable: шаг 4, изображение 3 из 3
    • Push up on the two dark grey pieces of plastic on the display ribbon cable bracket.
    • Make sure they are in a position similar to the one in the second image. Then they are fully extended.
    • Be very careful pushing on these as they are fragile and will break easily. If they do, the display cable will no longer be as secure and could have a bad connection.
  5. Game Boy Color Speaker Replacement: шаг 5, изображение 1 из 2 Game Boy Color Speaker Replacement: шаг 5, изображение 2 из 2
    • Using a spudger, screwdriver or other long thin object, gently pull the ribbon cable out of the bracket.
  6. Game Boy Color Speaker Replacement, Speaker: шаг 6, изображение 1 из 2 Game Boy Color Speaker Replacement, Speaker: шаг 6, изображение 2 из 2
    • If the speaker is simply dirty, clean it and the speaker holes in the case. Then, reassemble it and test the speakers. If they still don't work then continue on.
    • Once you've removed the motherboard, you are now free to desolder the speaker wires and replace it with a new one.
    • Make sure to keep the same polarity as the original, as otherwise it may sound a bit different. However, it likely doesn't matter and won't damage anything if the polarity is reversed.
Заключение
11 человек успешно провели ремонт по этому руководству.
Finn Dooley
Участник с: 03/09/22
419 Репутация
1 руководство автора
0 Комментарии к руководству
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 21
За последние 30 дней: 133
За всё время: 9,358
