Game Boy Screen Replacement
Выберете то, что вам нужно
  1. Game Boy Screen Replacement, Batteries: шаг 1, изображение 1 из 2 Game Boy Screen Replacement, Batteries: шаг 1, изображение 2 из 2
    • Switch your Game Boy off and remove the cartridge.
  2. Game Boy Screen Replacement: шаг 2, изображение 1 из 3 Game Boy Screen Replacement: шаг 2, изображение 2 из 3 Game Boy Screen Replacement: шаг 2, изображение 3 из 3
    • Use a fingernail (or small coin) to push down on the battery door latch and remove the battery door.
    • The release latch is a plastic spring clip. If your Game Boy is getting on in years, be careful as the plastic may be brittle.
    • When you're replacing the cover, be sure to get its two plastic tabs into the slots in the bottom of the battery compartment before pushing the cover back in place.
  3. Game Boy Screen Replacement: шаг 3, изображение 1 из 2 Game Boy Screen Replacement: шаг 3, изображение 2 из 2
    • Use a fingernail to pry each battery outward from the positive (+) terminal to remove them.
    • Dispose of used batteries properly!
    • Remove the batteries from your Game Boy before storing it for more than a month or so.
  4. Game Boy Screen Replacement, Outer Case: шаг 4, изображение 1 из 1
    • Remove the six Triwing screws from the back of the device.
  5. Game Boy Screen Replacement: шаг 5, изображение 1 из 1
    • Gently separate the device's front casing from the back casing after you remove the screws.
    • Be careful not to completely separate the casing halves, as they are still joined by a large ribbon cable that may be damaged.
  6. Game Boy Screen Replacement: шаг 6, изображение 1 из 1
    • Slide the front side of the casing down to expose the ribbon cable connector.
  7. Game Boy Screen Replacement: шаг 7, изображение 1 из 1
    • Grip the ribbon connector with your thumb and forefinger. Pull down gently until the connector, not the ribbon itself, comes out of its socket.
    • Separate the front and back casings.
  8. Game Boy Screen Replacement, Screen: шаг 8, изображение 1 из 1
    • Remove the ten screws that connect the circuit board to the outer case.
  9. Game Boy Screen Replacement: шаг 9, изображение 1 из 2 Game Boy Screen Replacement: шаг 9, изображение 2 из 2
    • Remove the circuit board from the outer case using a plastic opening tool.
    • Take care to gently pry around the entire outside edge of the circuit board until you can easily remove the board without force.
  10. Game Boy Screen Replacement: шаг 10, изображение 1 из 1
    • Disengage the the three plastic clips that secure the screen to the circuit board.
    I didn’t find this step necessary as the plastic screen holding unit is separate from the screen.
    skrolikowski - Ответить
  11. Game Boy Screen Replacement: шаг 11, изображение 1 из 3 Game Boy Screen Replacement: шаг 11, изображение 2 из 3 Game Boy Screen Replacement: шаг 11, изображение 3 из 3
    • Flip the circuit board over revealing the device screen.
    • Remove the two screws connecting the screen and the circuit board.
    • Follow the video instructions to desolder the display connectors and replace your screen.
Заключение
43 участников успешно повторили данное руководство.
Andrew Tramposch
Участник с: 06/24/10
2 225 Репутация
Автор 6 руководств
Команда
Cal Poly, Team 3-2, Johann Summer 2010 Участник Cal Poly, Team 3-2, Johann Summer 2010
CPSU-JOHANN-R10S3G2
3 членов
Автор 34 руководств
11 Комментариев
What kind of lcd screen or where can I find one that isn't off of another dmg-01 gameboy?
Floyd Odom - Ответить
I was wondering the same. Maybe ebay or Amazon.
Joshua Graham -
What about the new display? Where to get it?
No spare part necessary should be replaced with a link where to buy a new one.
Helmut Kohli - Ответить
You can’t buy a new replacement screen unfortunately. Not only is it very difficult to remove the screen, it’s impossible to buy a replacement. They’d be better showing us how to fix a screen. There’s plenty of videos on YT showing how to fix blank vertical line but hardly any on how to fix horizontal lines, and the ones that do don’t work very well.
Firegoose - Ответить
Where do I buy a replacement screen for a 1989 game boy?
Nathan Thurston - Ответить
i suggest maybe going on ebay and finding a gameboy thats either just for parts or has a working screen and desoldering it
Ethan Amos -
Habt ihr einen guten Tipp, wo man ein neues LCD herbekommt?
Car W - Ответить
I tried following the video and ended up with burned tabs and melted plastic. Basically it’s all ruined. OP does a terrible job.
Daniel Powers - Ответить
will this guide work to install a backlit LCD for the Game Boy? I have this Rips v4 backlit IPS LCD, and I figured I might as well install it.
if not, that's alright. I'll just find another guide.
Bella Marie - Ответить
AFAIK you can follow through the disassembly guide up to step 10 no problem, then it depends if you bought the full kit you simply swap the old screen and big PCB with the new ones; if you're planning to use the original GB case, notice you'll have to do some mods in order to fit in the new screen. Also, you might have to solder the speaker on the PCB. Here's a video you may want to check out when you're done disassembling the GB and will be ready to start installing the screen upgrade: https://www.youtube.com/watch?v=FMIJTbPe...
Simone -
bonjour ou puis je trouver l'ecran LCD ?
merci
nelly viaud - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 71
За последние 7 дней: 594
За последние 30 дней: 1,997
За всё время: 133,474
