Garmin Approach S2 Motherboard Replacement
Выберете то, что вам нужно
  1. Garmin Approach S2 Motherboard Replacement, Back Cover: шаг 1, изображение 1 из 2 Garmin Approach S2 Motherboard Replacement, Back Cover: шаг 1, изображение 2 из 2
    • Remove the six T5 Torx 6.32mm screws securing the back cover to the watch.
  2. Garmin Approach S2 Motherboard Replacement: шаг 2, изображение 1 из 1
    • Remove the back cover carefully.
    • Even after the screws have been removed, the back cover can still be quite difficult to take off. Moderate to extensive prying may be required. Be gentle, but firm.
  3. Careful: step 3 is sourced from a guide that's marked as in-progress.
    Garmin Approach S2 Motherboard Replacement, Water Proof Gasket: шаг 3, изображение 1 из 1
    • Remove the orange gasket.
  4. Garmin Approach S2 Motherboard Replacement, Screen: шаг 4, изображение 1 из 1
    • Remove the screen and motherboard assembly from the case.
  5. Garmin Approach S2 Motherboard Replacement: шаг 5, изображение 1 из 1
    • Use a metal spudger to remove the golden retaining clip from the screen. There will be some adhesive to break.
  6. Garmin Approach S2 Motherboard Replacement: шаг 6, изображение 1 из 1
    • Remove the screen from the golden metal clip.
  7. Garmin Approach S2 Motherboard Replacement: шаг 7, изображение 1 из 1
    • Unhinge the black retaining hinge by prying it open with the metal spudger; Your fingernails will work as well.
  8. Garmin Approach S2 Motherboard Replacement: шаг 8, изображение 1 из 2 Garmin Approach S2 Motherboard Replacement: шаг 8, изображение 2 из 2
    • Remove the connector from the motherboard by pulling it free at the base.
    • Make sure to pull from the base of the connector wire, as it is very easy to rip the wire from the screen.
  9. Garmin Approach S2 Motherboard Replacement: шаг 9, изображение 1 из 1
    • Remove the screen from the motherboard.
    • Notice our tape retaining the connector to the screen. This is so easy to rip!
  10. Garmin Approach S2 Motherboard Replacement, Motherboard: шаг 10, изображение 1 из 1
    • Remove the motherboard from the screen.
Заключение
Evan Miller
Участник с: 03/21/18
250 Репутация
Автор 2 руководств
Команда
IUPUI, Team S4-G1, Baechle Spring 2018 Участник IUPUI, Team S4-G1, Baechle Spring 2018
IUPUI-BAECHLE-S18S4G1
3 членов
Автор 4 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 4
За последние 30 дней: 14
За всё время: 691
