Введение
In this guide there are delicate parts that will very easily break under tension. Keep this in mind as your move forwards.
Выберете то, что вам нужно
Remove the six T5 Torx 6.32mm screws securing the back cover to the watch.
Шаг 3 Water Proof Gasket
Careful: step 3 is sourced from a guide that's marked as in-progress.
Remove the orange gasket.
Use a metal spudger to remove the golden retaining clip from the screen. There will be some adhesive to break.
Unhinge the black retaining hinge by prying it open with the metal spudger; Your fingernails will work as well.
Еще один человек закончил это руководство.
